Post by Keith - Portsmouth on Apr 4, 2005 13:46:25 GMT
A simple question, and no doubt a simple answer... If I unscrew all the screws securing a hinge to the A post (or B/C post), what happens to the tapped metal plate inside the post? Does it disappear to the bottom of the post or is it retained in position in some way? Thanks, Keith.
Post by Phil Nottingham on Apr 4, 2005 15:55:01 GMT
;DIt should be retained by a metal cage like affair - but if your A post has rusted the cage like affair goes with it. If your A post has corroded simply trying to remove the screws, as you will need at least an impact driver will soon give the game away
Post by glennr on Apr 4, 2005 21:49:37 GMT
Phil is right, the plate is retained in a bracket and should move around in a limited 360 degree movement to allow adjustment. When I did my 'A' post repair in the off side the lower retaining bracket had corroded and the plate would fall into the sill.
Post by Keith - Portsmouth on Apr 5, 2005 23:48:31 GMT
Thanks gents for your responses. As the screws moved freely, I took the plunge and removed them. The back plates remained in place... what a relief! Thanks again. Keith.
