Post by petervdvelde on Aug 5, 2016 21:53:19 GMT
nice job!
Post by wozzer on Aug 7, 2016 12:57:39 GMT
Thanks guys. Spent time this week cutting and shaping the chassis reinforcing plates ready to mount the air bag brackets. Also spent time preparing the off side chassis rail which involved removing and grinding back the original shock turrett where it was attatched to the chassis, this then makes room for the brackets with no obstructions. This is one of the plates cut and shaped, still a bit to do on this to shape the ends but its almost done.
Post by johnwp5bcoupe on Aug 11, 2016 8:59:41 GMT
Post by wozzer on Aug 12, 2016 18:45:37 GMT
Thanks for the link john, seen somthing very similar, theres some very clever people around
Post by wozzer on Aug 13, 2016 18:07:58 GMT
This is the modified lower bag bracket This pic shows the modified upper bag bracket fully welded to the chassis strengthening bracket ready to be installed.
Post by wozzer on Aug 13, 2016 18:11:43 GMT
These two pics show the upper and lower brackets in place with the bag all bolted together. Just need to complete the other side so i can re check my measurements ready for installation. Woz
Post by wozzer on Aug 19, 2016 19:41:12 GMT
Machined up these eight chassis spacers which will be welded into the chassis ready to accept the upper bag mount.
Post by wozzer on Aug 19, 2016 19:50:11 GMT
This is the chassis spacers welded in place. This pic shows the top mount bolted in place. This bracket was originally going to be welded in but i have decided to change plans a little and bolt this in to aid maintenance and to make it easier to gain access to the air connections and top bolts. Woz.
Post by enigmas on Aug 20, 2016 6:25:08 GMT
Lookin' good Woz...very nice attention to detail.
Post by gingerbeer62 on Aug 20, 2016 8:35:12 GMT
Following with interest as engineering is always interesting to me.
I am wondering how this all affects the legal side of things ? What about insurance etc. How do you explain what you do to them. Are there any problems with them ?
Most Insurance companies seem to want to know even about stuff like change of shock absorbers etc. How do your mods fare with them?
Cheers Colin
Post by wozzer on Aug 20, 2016 9:37:35 GMT
Lookin' good Woz...very nice attention to detail. Many thanks mate im hoping to have the other side done very soon so i will be able to get it out into the sunshine and get a good look at it Woz.
Post by wozzer on Aug 20, 2016 9:44:09 GMT
Following with interest as engineering is always interesting to me. I am wondering how this all affects the legal side of things ? What about insurance etc. How do you explain what you do to them. Are there any problems with them ? Most Insurance companies seem to want to know even about stuff like change of shock absorbers etc. How do your mods fare with them? Cheers Colin Hi colin These mods will not cause any problems regarding the insurance etc. providing you go to the right companies. As far as the legallities are concerned then the way the rules stand at the moment it will fall well within the 8 point rule which will mean that it will not need any further testing (biva) and therefore will keep its original identity and original registration. Thanks for your interest Woz
Post by johnwp5bcoupe on Aug 20, 2016 11:44:24 GMT
Wozza not knocking your project its progressing well Just concerned about the 8 point rule and keeping your plate! Part Points Chassis, monocoque bodyshell (body and chassis as one unit) or frame - original or new and unmodified (direct from manufacturer) 5 Suspension (front and back) - original 2 Axles (both) - original 2 Transmission - original 2 Steering assembly - original 2 Engine - original 1
Post by gingerbeer62 on Aug 20, 2016 15:28:49 GMT
Following with interest as engineering is always interesting to me. I am wondering how this all affects the legal side of things ? What about insurance etc. How do you explain what you do to them. Are there any problems with them ? Most Insurance companies seem to want to know even about stuff like change of shock absorbers etc. How do your mods fare with them? Cheers Colin Hi colin These mods will not cause any problems regarding the insurance etc. providing you go to the right companies. As far as the legallities are concerned then the way the rules stand at the moment it will fall well within the 8 point rule which will mean that it will not need any further testing (biva) and therefore will keep its original identity and original registration. Thanks for your interest Woz What is the 8 point rule ? Cheers Colin
Post by johnwp5bcoupe on Aug 20, 2016 16:11:41 GMT
See my post below/above depends where you view it Colin
Post by wozzer on Aug 20, 2016 19:09:08 GMT
Ive worked it all out john no worries its fine. Woz
Post by enigmas on Aug 20, 2016 23:44:25 GMT
People build hotrods, custom cars and all sorts of modified and innovative machinery if they have the skills and the fortitude to see these projects through to completion. There are certified engineers available to assess this type of work and provide reports. Hey gents, how about just watching the build progress as it's in the 'modified'section and not dissuading Wozza from posting updates through deflection! A debate over the insurance issue can be created elsewhere on the forum surely, if there's a strong desire for it and if it doesn't currently exist. Personally, I'd like to see Woz's skills take the work through to completion. NB. Posting anything in the modified section here takes courage, hence the limited number of people doing so, and posting elsewhere!
Post by johnwp5bcoupe on Aug 21, 2016 5:15:33 GMT
People build hotrods, custom cars and all sorts of modified and innovative machinery if they have the skills and the fortitude to see these projects through to completion. There are certified engineers available to assess this type of work and provide reports. Hey gents, how about just watching the build progress as it's in the 'modified'section and not dissuading Wozza from posting updates through deflection! A debate over the insurance issue can be created elsewhere on the forum surely, if there's a strong desire for it and if it doesn't currently exist. Personally, I'd like to see Woz's skills take the work through to completion. NB. Posting anything in the modified section here takes courage, hence the limited number of people doing so, and posting elsewhere! I am intrigued in what Wozza is doing Vince so I am not deterring him in his quest! I enjoy a challenge myself The question asked about insurance was in good faith IMHO others may like to know for their own reasons not to deter Wozza Keep posting Wozza it's your section! good shed engineering
Post by gingerbeer62 on Aug 21, 2016 8:13:51 GMT
I looked up the 8 point rule and learned something there. I can tell my son his shocks are ok. You are doing a very interesting mod and will no doubt be a great improvement on the original. Looking forward to seeing it how it sits when done. Like the airbag suspension. You doing all this very skilled work is driving me to try and find out why my suspension squeaks ? Cheers Colin
Post by wozzer on Aug 25, 2016 18:17:32 GMT
The final setup photo taken from in front of the axle. Just needs the axle dropped and a couple of welds to finish a couple of brackets. I have the air management system being delivered tomorrow so i should have the system working by the weekend with a bit of luck, then i can get the car on the ground and take a few pics outside in the sunlight. Woz.
Post by wozzer on Sept 3, 2016 19:18:58 GMT
Made up the final piece of the rear jigsaw which is the crossmember/strut brace which will locate the upper shock mounts Here it is bolted into place it works really well as a strut brace and stiffens the structure up immensely well
Post by bissmire on Sept 6, 2016 19:24:20 GMT
Very tidy.
Post by wozzer on Oct 22, 2016 18:52:48 GMT
Thanks guys. Got the old girl back together to see what see looks like, got her started and into the fresh air here are a couple of pics Up Down Three quarter veiw. Start on the front tomorrow.
Post by wozzer on Oct 22, 2016 19:30:55 GMT
A short video
Post by enigmas on Oct 22, 2016 21:01:11 GMT
Great work Wozza, not only the suspension changes but also the care you take in the engineering of your car.
Perhaps I've missed something but how are you going to deal with the front suspension? At full drop the car will sit on the bump stops...and even then it's not that low. (The query is in relation to maintaining viable suspension movement for a low and comfortable ride)
