Post by Grant iambiggles on Jul 4, 2005 23:12:26 GMT
..... well I assume its something like that - but I've yet to figure out how to get the door trim panel off!! I know how to remove the handles (d**n - its so much easier on my Morris Minors), but getting the panel off seems to require removing the wood trim/capping at the top - and getting this off seems to require removing other bits.
Is there an easy way to gain access to the regulator to check if its missing teeth or just slipped?
Ta Muchly
Post by Keith - Portsmouth on Jul 5, 2005 0:39:09 GMT
Once you've taken the handles off, you need to remove the adjustable arm rest (if its a coupe front door). If its a saloon, I think the armrest still has to come off but I'm not sure. The panel comes off before the wood - the wood is fixed by screws behind the panel. This is all detailed in the workshop manual.
Post by glennr on Jul 5, 2005 6:22:55 GMT
Post by Grant iambiggles on Jul 5, 2005 8:18:29 GMT
Fantastic - Thanks Glenn!!
