Post by enigmas on Sept 15, 2016 11:28:40 GMT
Post by Warwick on Sept 16, 2016 11:50:51 GMT
Nice gloves, Vince. Calf skin?
Post by enigmas on Sept 16, 2016 12:25:08 GMT
What gloves!
Post by wozzer on Sept 16, 2016 17:19:03 GMT
Didnt realise your bags had springs around them, what sort of rating are they?
Post by enigmas on Sept 16, 2016 21:03:23 GMT
Polyair make some really functional and compact bags. Here's the rating below ( company blurb) on the red series. Mine are spring assisters and come with the thin outer coil to contain/locate the bag. The coil has no other dynamic function. Polyair Red SeriesPolyair Red Series bags are designed to fit inside the coil of a coil sprung vehicle to assist the spring in supporting whatever load is placed in the vehicle (within manufacturers recommended gross vehicle weight rating). They help in eliminating “bottoming out” and improve ride, handling and stability. The air adjustability allows you to tune the ride you want, whether you’re hauling, towing or riding light! Made with tough, long-lasting, moulded polyurethane. Features and benefits of the Polyair Red Series Add support to rear springs on many vehicles. Improves muscle car traction for drag racing. Improves ride and handling for full-size vans with front coils. Fits open coil springs, front or rear. Up to 450kg (1,000 lbs) of levelling capacity.* Air adjustable for the ride you want. Reduces roll, sway and “bottoming out.” Quick connecting easy-to-use engineered polymer air fittings. Tough moulded polyurethane construction. 2 year, unlimited km warranty. Here's a nice little video. Note these black series and how easy they would be to adapt if you wanted to retain the original leaf spring. www.youtube.com/watch?v=W5IswR_MFDk
