Post by Eric R on Oct 4, 2016 14:24:00 GMT
Cant find a reference in Owners Handbook or threads but I see the green turn indicator light flashing on my P5B but are they silent? As the unit is on the bulkhead in the engine bay is it expected to be audible in the cabin?
Post by johnwp5bcoupe on Oct 4, 2016 16:30:48 GMT
The flasher unit is in the Binacle Eric the 3AW is the can on the Bulkhead
Post by Eric R on Oct 4, 2016 18:43:19 GMT
so ticking sound should be in the binnacle? Replacing that then should rectify? Thank you John
Post by lagain on Oct 5, 2016 8:12:08 GMT
There is a much better replacement for the flasher unit than the original. A Lucas SFB 162 which is available on ebay. It is electronic and the flash is consistant. It has 3 terminals 31 goes to earth, 49a goes to the switch - light green / brown wire 49 goes to power - green wire
Post by Eric R on Oct 5, 2016 11:32:05 GMT
wow - now thats interesting! Although my P5 Mk1 is working but very quiet, I will buy two.
Post by Phil Nottingham on Oct 5, 2016 17:38:03 GMT
Unless the 3 litre has had the polarity reversed the electronic one will not work correctly if at all .
P5B's will need the warning lights wiring altering if it has the early 3 pin type as fitted to the 3 Litre. the 2 pin later type is noisier if mounted correctly and wiring mods also required to make best use of an electronic version
Post by lagain on Oct 5, 2016 18:40:29 GMT
As far as I can remember when I fitted the electronic flasher all I had to do was make up an earth wire as the original one is earthed through the mounting.
The electronic unit will flash at exactly the same speed whatever the revs, unlike the Rover original
Post by Phil Nottingham on Oct 5, 2016 19:00:03 GMT
Yours is the later model
