Post by PatMcCoy on Oct 25, 2005 12:20:01 GMT
Ive just pick up a set of secondhand seats and I'm going to order the Gliptone leathercare dye Have cleaned seats twice and need to feed them before i use the dye Which leather feed do you use ?,or were can i buy it
Post by p5tgc on Oct 25, 2005 13:02:56 GMT
I have used the Connolly hide food, which is a thick cream, and the Gliptone conditioner, a thinner liquid. Of the two, I would recommend the Gliptone, as it is easier to use and seems to penetrate into the leather quicker. The Connolly stuff takes days to sink in, the Gliptone only hours.
Post by PatMcCoy on Oct 25, 2005 13:13:22 GMT
Does the leather feed soften up the leather ? Does it give it a better chance for the dye to take? And easier to apply?
Post by Deleted on Oct 25, 2005 13:25:50 GMT
The Gliptone product smells really nice too, just like it says on the bottle !! Freddy
Post by Phil Nottingham on Oct 25, 2005 17:34:08 GMT
Yes to both
Post by dorsetflyer on Oct 25, 2005 19:39:50 GMT
I'm surprised about feeding the leather BEFORE using the feed to soften it. Surely the order should be, 1. Clean the leather. (this does help to soften it) 2. Colourwash the leather. 3. Feed the leather.
Post by Phil Nottingham on Oct 25, 2005 20:38:34 GMT
Some makes do advise softening up the leather so that it will soak up more colour
Post by Deleted on Oct 26, 2005 7:24:06 GMT
I think the product with a Frech sounding name advises this too. LEATHERIQUE, thats the one I was thinking of!!
Post by Peter Mueller on Oct 28, 2005 15:23:48 GMT
I have used a set from Woolies with excellent results and they recommend to clean and FEED it first before putting on the dye. In my experience it works well.
Post by PatMcCoy on Oct 29, 2005 10:46:17 GMT
Just an update Look on the net yesterday and Saab dealers sell Gliptone products Gliptone cleaner £4.00, Gliptone feed £4.90 Saves the hassle and p+p I got a bottle of each
Post by glennr on Oct 29, 2005 14:22:22 GMT
I saved these recommendations from the old web site Can anyone recommend the best way to feed,clean and re-stain/paint seats. I have the buckskin colour ones. Regards, Simon Author: willDate: 9/18/2003 12:30 am EDT various products, i've tried Woolies (too plasticy), connolly (too shiny) and Leatherique, definitely the best, with work it will soften cardboard leather back to original softness, the dye is water based so allows the leather to breathe and can be mixed as a gloss, matt or satin, plus you can vary the level of sheen by how you apply it try a sample of their restorer www.leatherique.com/good luck Will Author: Alan- LeicestershireDate: 9/18/2003 1:18 pm EDT I have also had good results with softening the leather with the Leatherique products. Never tried their colouring though. Woolies colourings work best if sryaed on in thin coats so the grain of the leather is not clogged up Author: John......WeymouthDate: 9/18/2003 3:27 pm EDT I have not tried Leatherique, but have used Gliptone. I found that their Scuffmaster colour for Buckskin was perfect for my car, I did'nt have to alter the colour at all. Their conditioner is good too and you end up with a lovely smell of leather in the car. If you go to Gliptones site on the web they go through the whole process of leather renovation, they are based in Todmorden. www.liquidleather.com Regards John Author: dave leeDate: 9/18/2003 3:52 pm EDT Hello Simon, I did my buckskin seats several years ago with a kit from trim suppliers "Wollies" from Peterborough way. just send a small square of leather to them & they will send the kit to match. The secret is to apply several coats of the refurbish colour (say around 5) to achieve a uniform appearence I did apply the last coat by brush if I remember & if done properly does look really nice. Then apply the sealer.If you live near Southampton I can do a seat for you & then you can do the rest. Sorry but I do not have Wollies Tel No to hand but they are in the classic car mags. David.
Post by PatMcCoy on Nov 5, 2005 2:59:26 GMT
Well i cleaned seats twice Fed them twice with Gliptone feed The instructions on the bottle of dye is to dilute it 10 to 15% Have put some on a seat with a cloth, but its a bit streaky,mind you its only a thin first coat. Do you rub it in or dab it as the bottle says? Does it cover better on second coat or should i use a brush How do you put yours on? Plus it seems to come up a matt finish is this correct?
Post by dorsetflyer on Nov 8, 2005 16:31:17 GMT
Yes it does come up matt finish, but once it's dried out using the feed will eventually put a sheen back on. The idea is to dab it on, or gently rub it over the surfaces using the sponge they provide. Two coats should be sufficient though. For large cracks I use a cottonbud dipped in a neat solution. The main thing is not to fill the cracks only colour them.
