Post by stan on Nov 17, 2017 19:21:43 GMT
An odd request but does anyone have a picture of their rear parcel shelf (saloon)?
Mine has 2 square vinyl covered pads either side of the window? They look like ply maybe glued on? What is behind on the corners of the shelf please?
I can see the factory seatbelt mounts behind the boot liner from inside?
In the.midst of fitting new inerta reels all round and yes I read all the threads on belts but the only pics are from a P5B coupe. (Nice coupe btw).
Thank you
Post by Phil Nottingham on Nov 17, 2017 20:34:42 GMT
It is just a single piece of flat shaped standard hardboard covered with leather cloth which merely rests on the rear steel panel and held in by the fillets under the screen and glued to the panel behind the seat.
Coupes and Mk1 saloons are different
Post by stan on Nov 17, 2017 21:29:32 GMT
It is just a single piece of flat shaped standard hardboard covered with leather cloth which merely rests on the rear steel panel and held in by the fillets under the screen and glued to the panel behind the seat. Coupes and Mk1 saloons are different Thanks Phil but mine seems to be metal and with a moulded centre section which is sculped to be recessed? Very odd will take a pic in the morning.
Post by Phil Nottingham on Nov 17, 2017 21:37:37 GMT
That is the early version
Post by stan on Nov 17, 2017 22:29:15 GMT
That is the early version Ok so maybe someone has glued 2 pieces over the ends? Either way I need to lift them up to see what's behind and sort out seatbelt mounts. So does anyone have a photo of what they look like please?
Post by ozriderp5 on Nov 17, 2017 23:05:54 GMT
Post by stan on Nov 18, 2017 9:30:15 GMT
Thank you that is exactly what I needed to see? Ok so maybe someone has just glued the ends over to make them look nicer. Ok off they come, seatbelts more important , mayne sneak some speakers in there somehow?
Post by ozriderp5 on Nov 18, 2017 10:25:43 GMT
As you can see mine look like they've had speaker holes cut. I dont know whats under them yet.
Post by stan on Nov 18, 2017 16:08:29 GMT
As you can see mine look like they've had speaker holes cut. I dont know whats under them yet. Be afraid there could be dead body parts or monsters lurking! 😂😂😂 Thank you for sharing its a big help now I have no fear to rip mine out! I will have to wear my welders mask and welding gloves , dont want some huge spider to run out cross that I disturbed his home?
