Post by johnwp5bcoupe on Dec 5, 2006 9:33:16 GMT
I am a bit confused on the fitting! there is a small section "C" which you can fit either way round and is too wide to fit anyway so I emailed Scott this was his reply after telling him it was a Coupe Kit :- Section C is only a 200mm length that fits in some doors, not all. It is used to fit any way you can. If the whole kit has 1.5 metres of section C, then it is probably a sedan kit! Thankyou, Scott. So is he saying you don't need to fit the small section "C" anybody else had a similar problem with the new kits I thought all Coupe doors were the same I will let you know his reply.
Post by Keith - Portsmouth on Dec 5, 2006 15:56:46 GMT
I've used Scott's seals but only done the rear doors of my coupe so far. The instructions do suggest that the section 'C' can be used on the rear, but I didn't bother. Keith.
Post by johnwp5bcoupe on Dec 5, 2006 18:09:30 GMT
Hi Keith the rears are straight forward you use section"C" if you are a bit short! but on the front ones it says fit it the length of the Stainless Steel cover! I will see what Scott says
Post by johnwp5bcoupe on Dec 6, 2006 7:21:07 GMT
Here is the reply :- It is entirely up to you, some people use a little of it where the other seals join, other people find they do not need it. Thankyou, Scott.
Post by Deleted on Dec 6, 2006 8:46:41 GMT
Aussies eh!
They've learnt to make anything fit anything 'cos they are so far from the rest of the civilised world!
Post by Deleted on Dec 6, 2006 10:10:48 GMT
obviously your cricket team found it a bit of a stretch too. neil , south australia.
Post by David on Dec 6, 2006 11:41:40 GMT
Tell us about it. And we will not even mention the Rugby ;D
Post by glennr on Dec 6, 2006 22:42:36 GMT
Hang on, it's not over till the fat lady sings!!!
