taz
Post by taz on Jan 16, 2007 10:54:46 GMT
Hi folks, Hoping someone can help... How do you remove the fuel filler so I can paint around the recess? I've managed to loosen it by pulling off the rubber hose within the boot (and broke off a section of the inner pipe in the process ), but It appears that I cannot remove it unless I break the plastic collar that holds the fuel cap locking pin. Also, does anyone know how to remove the small chrome wiper rest ramp thingo on the drivers side? Thanks in adv. Cheers, Taz.
Post by Keith - Portsmouth on Jan 16, 2007 12:43:20 GMT
The fuel cap locking pin housing is just screwed on. The plastic bit is hexagonal - find a spanner to fit and unscrew it. You will then be able to remove the filler easily - without breaking anything.
Post by stevem on Jan 16, 2007 13:24:14 GMT
The small chrome wiper "rest ramp thingo" on the drivers side just pulls out of two small plastic seats. Lever out carefully to avoid damage. Steve M
Post by Phil Nottingham on Jan 16, 2007 18:20:42 GMT
Make sure you repair the inner pipe and position it correctly otherwise it will make it an awfully slow tank filler and I mean slow!
Post by johnwp5bcoupe on Jan 16, 2007 19:32:01 GMT
Anyone know where you get the plastic plugs to fix the badges etc
Post by PatMcCoy on Jan 16, 2007 19:41:56 GMT
Wadhams sells them
Post by glennr on Jan 16, 2007 21:25:16 GMT
taz
Post by taz on Jan 16, 2007 23:15:13 GMT
Many thanks for your help folks.
I did try to unscrew the hex shaped plastic housing with a ring spanner, but the spanner burred over. I will try again. Maybe a hex shaped socket will do the trick.
Phil - As the inner pipe broke at the filler, can I simply pull out some excess from the tank end and re-attach? Or will pulling an inch or two out of the tank cause problems at the tank end?
Post by Phil Nottingham on Jan 17, 2007 9:48:28 GMT
You can try - it may stretch enough
