Post by pipetech on Jan 6, 2020 22:32:23 GMT
As heading says guys, I'm in need of a pair of front wings. Mine are pretty bad but I might have to repair them if none are about. Cheers
Len
Post by Sam Bee on Jan 6, 2020 22:48:57 GMT
What is your car? Voking2000 has P5B Coupe NOS R/H on ebay and has a L/H available too - £650 a PAIR. Brand new! I had a R/H from him. Only snag is that the holes for the trim strip and indicator repeater are not present. I do have a used L/H, stripped and in primer, with slight attention required at bottom rear.
Post by johnwp5bcoupe on Jan 7, 2020 9:10:09 GMT
As heading says guys, I'm in need of a pair of front wings. Mine are pretty bad but I might have to repair them if none are about. Cheers Len Len if your wings on the car are the original I would repair them if you can, a lot of the new wings floating around are old pattern ones and they don't fit very well! the drain valley is the wrong shape and doesn't fit the bonnet ie the gap is wrong! if you are apt at panel work that can be sorted. You may be lucky and get an OEM wing but even then due to pressing age it may need a bit of fettling
Post by Brendan69 on Jan 7, 2020 19:47:53 GMT
2 x OEM front wings on ebay for £1000
Post by Roy of the Rovers on Jan 10, 2020 17:01:16 GMT
As heading says guys, I'm in need of a pair of front wings. Mine are pretty bad but I might have to repair them if none are about. Cheers Len Replied to your message Len
