Post by gerryp on Mar 17, 2020 18:51:55 GMT
Hi does any body know if it possible to remove the camshaft and bearings without removing the engine on a mk11 3 litre many thanks
Post by djm16 on Mar 17, 2020 23:43:53 GMT
I am going to hazard a guess at YES, but it will involve making a hole in the firewall to remove the rear rocker shaft. You may also have difficulty drifting out the camshaft from the rear even if you can get the cam shaft cover plate off. Ditto the rear camshaft bearing.
You may want to have a look at my thread on rebuilding a 3-litre engine.
