Post by Roy of the Rovers on Mar 18, 2020 11:36:52 GMT
Has anyone on here got experience of fitting the 4 speed auto from an LDV Ambulance to a P5B? I have a spare prop (2 piece with cage)and I'm looking to take it on Friday to be refurbished and balanced but also shortened. Does anyone know the length to shorten it by (having had it done or assisted in a conversion)? Is it the long prop or short prop that is shortened? Sorry for the questions... Thanks Attachment Deleted
Post by enigmas on Mar 18, 2020 12:51:53 GMT
Hi Roy, Shortening and attaching the propellor shaft is about the last thing you want to do after fitting the ZF trans to your P5B. The Jag XJ40 trans (ZF) that I'll fit at some stage won't require any alterations to either its length or the flanges and will bolt straight up.
With any luck I believe yours will too. If the trans output flange is in the same place as the current BW35...then problem solved.
PS. I'm assuming you've measured and/or marked the relative position of the current assembly.
People who can assist
Owen Vincent Peter de Velde
Post by Roy of the Rovers on Mar 18, 2020 14:54:33 GMT
Hi Roy, Shortening and attaching the propellor shaft is about the last thing you want to do after fitting the ZF trans to your P5B. The Jag XJ40 trans (ZF) that I'll fit at some stage won't require any alterations to either its length or the flanges and will bolt straight up. With any luck I believe yours will too. If the trans output flange is in the same place as the current BW35...then problem solved. PS. I'm assuming you've measured and/or marked the relative position of the current assembly. People who can assist Owen Vincent Peter de Velde Hi Vince, no the car is still completely assembled. The reason I'm asking is because the conversion has been done already by lots of people to their P5s using the LDV Ambulance box. It was the easiest to get originally now LDVs have turned into the rare parts from a unicorn! So nowadays people will use the box from a jag or BMW and I cannot speak for that conversionor gearbox length, the LDV rwd box has a known length and is a known conversion. Hopefully someone has the details.. Thanks for the recommendations. The prop definitely needs shortening with this conversion, I just need the details! regards Roy
Post by harvey on Mar 18, 2020 15:13:38 GMT
The measurement you need is somewhere on this forum because I'm sure I can remember posting it a good while back after being involved with doing the conversion using an LDV box. I can't remember what it was exactly but ISTR it was 80-something mm.
Post by petervdvelde on Mar 19, 2020 6:24:59 GMT
I am not really sure but i believe it was 86mm. The one i got shortened is the long one as you do not want to change the position of the the bearing. It is good to make a jig with the original in the car to maintain the correct driveshaft angle. Just make a piece of wood (with a half circle cut out) what you can put between the driveshaft and the subframe. Later you can use this jig to make the mounting bracket for the box to subframe connection Peter
Post by eightofthem (Andy) on Mar 19, 2020 11:18:26 GMT
88mm Roy. ( in standard 22 form )
Front section. Good advice on making a jig beforehand to establish the correct position before removing the BW box, the mounting plate on the cross member will need to be moved from the front, to the back.
Post by Roy of the Rovers on Mar 19, 2020 14:12:24 GMT
88mm Roy. ( in standard 22 form ) Front section. Good advice on making a jig beforehand to establish the correct position before removing the BW box, the mounting plate on the cross member will need to be moved from the front, to the back. Andy will that change with you beefing my 22 up to 24 spec?
Post by eightofthem (Andy) on Mar 19, 2020 18:31:00 GMT
Yes It will make the overall length longer by 13mm, so the prop would need 101mm chopped off.
