Post by wailofthebanshee on Aug 29, 2021 14:18:39 GMT
As my washer bottle is fastened to the car with tierips I wonder if anyone could post a good picture of the washer bracket so I could either look for one or make one myself>Thanks!Mike
Post by p5andrew on Aug 29, 2021 16:58:49 GMT
Which type of washer bottle do you have? The mountings vary... I do know that Wadhams market the bracket for the latest plastic type. The various types of bottle were also used by other manufacturers and they and the brackets may well be available from other sources if you require one.
Post by Phil Nottingham on Aug 30, 2021 6:35:55 GMT
Most P5Bs have the common triangular wedge type which is used on many cars. Earlier P5s had a rubber strap and the really early ones with a glass bottle is metal strapping
Post by wailofthebanshee on Aug 30, 2021 19:26:19 GMT
thanks;it is indeed a plastic bottle with a triangular form in it on the back;the bracket i have does not line up with the holes in the body and i am reluctant to drill new ones..
Post by Phil Nottingham on Aug 30, 2021 21:11:44 GMT
I will check tomorrow but seem to think the triangular bracket screws to another one that bolts onto the inner wing
Post by Sam Bee on Aug 31, 2021 10:14:25 GMT
Photos will help! There are three self tapping screws holding the bracket and plastic triangular spacer (the latter sandwiched between bracket and inner wing).
Post by wailofthebanshee on Sept 4, 2021 17:36:14 GMT
Thanks for your answers!!Problem solved;by accident I found one on a scrap P5;nearly everything else was removed...
