Post by jeff5b on Sept 16, 2021 15:13:09 GMT
I'm, hopefully, on the last leg of a very long restoration on my P5B Coupe, but still with many small jobs to do. One job I need help with is re-fitting the side chrome trims. During the bodywork and respraying, I have lost all the pop-rivet holes for the body clips and also the position of the right hand wiper rest. Does anyone have the measurements of where to drill all the holes, and maybe what number drill I should use? All help greatly received.
percy
Post by percy on Sept 16, 2021 18:14:27 GMT
All the dimensions are clearly set out in the Rover 3 litre workshop manual for the Rover P5 mark 111.
Post by lagain on Sept 17, 2021 16:10:45 GMT
I am sure that you are aware of this, but when drilling holes in the door use minimum pressure to avoid denting the door, if possible perhaps use a wood block on the inside.
