Post by disco1 on Jul 13, 2022 17:43:29 GMT
Hi all Just wondering if you have had a similar fault to the latest puzzler The reverse lamp has stopped illuminating and have had the boot assembly apart today and can measure 12.8v to the bulb supply but the bulb will not light up . The side lights work ok and have used one of the side lights red wire to supply the middle reverse bulb and it lights up Do you think it is an inhibitor switch fault ? Or should I be looking elsewhere? Thanks in inticipation
Chris D Zircon blue saloon Lives in Torquay
Post by dmaxwell on Jul 13, 2022 18:11:56 GMT
Have you verified that the ground is good? Having voltage at the positive side doesn't help if there is no ground path! Just a thought.
David California
Post by Phil Nottingham on Jul 13, 2022 20:14:49 GMT
Try the obvious above before considering the inhibitor switch! Some are adjustable some are not but either way you need to have slim double jointed finger
