Post by toffer22 on Jul 19, 2022 9:55:32 GMT
Hello. . I need advice on the BVA of my Rover P5B 1971. In position D the third gear does not engage. Is it a problem in the box or something else? thanks a lot
Post by harvey on Jul 19, 2022 13:59:25 GMT
Hello. . I need advice on the BVA of my Rover P5B 1971. In position D the third gear does not engage. Is it a problem in the box or something else? thanks a lot Providing the linkage and cable are correctly adjusted, if TOP gear is the only gear you have lost it's a rear clutch fault, if you have lost TOP and REVERSE it's a rear band fault. Only caveat to that is the possibility of a governor fault, but I've never experienced a governor give that problem.
