Post by timhanna on Sept 26, 2022 0:13:18 GMT
Has anyone mated a P4 manual gearbox to a 3 liter P5?
Post by Phil Nottingham on Sept 26, 2022 4:42:21 GMT
See search - different casing as P4 has the rear engine mounting cast into it
Post by Sam Bee on Sept 26, 2022 15:52:50 GMT
There are good manual gearboxe alternatives that bolt straight on. But gear change linkage needs changing.
Post by timhanna on Oct 4, 2022 4:53:10 GMT
In this case I am putting the 3 liter in a 95 and it seems pretty plausible to me. The 3 litre I have had an auto behind it so I will have to machine a flywheel to fit but otherwise it looks reasonably straight forward. Some others have apparently already done this here in NZ but the one I know about died a while back. If nobody has done it over there then I guess that's that but I believe it will make a good combo in the car.
Post by Phil Nottingham on Oct 4, 2022 5:23:50 GMT
There have been a few 3 Litre conversions in P4s in the UK but these have been the manual engine. The auto crankshaft is not machined for the spigot bushes and the flywheel holes are different
