Post by biffofo on Sept 30, 2022 16:21:27 GMT
Hi I am tidying up the wiring in the engine bay. Was wanting to upgrade the flasher relay to handle LED bulbs but confused now as to where the original one is I have found a relay ? a silver cylindrical canister at the side of the Fuse box attached to the body three connectors on it marked E AL WL . these do not seem to correspond to my flasher relay with X P L terminals so methinks the silver one isnt the flasher !! if not where is it ?
can some one please advise on this thanks
Post by jorhenderson on Sept 30, 2022 19:25:28 GMT
that thing you have found is the 3AW, it brings on the warning light for the alternator (thats what WL stands for.)
Post by Mike’S-a-loon on Sept 30, 2022 20:23:55 GMT
The flasher unit is inside the car, up under the dash.
Post by Ken Nelson on Oct 2, 2022 14:51:20 GMT
In my 1966 P5 3-litre Coupe the flasher unit is inside the instrument binnacle and accessible by removing the front of it. I don't know about the P5B.
Post by Phil Nottingham on Oct 3, 2022 10:11:51 GMT
In my 1966 P5 3-litre Coupe the flasher unit is inside the instrument binnacle and accessible by removing the front of it. I don't know about the P5B. On the P5B early models with 3 pin can is on the back of the speedo etc. On later P5Bs with the 2 pin Clicker can it is hanging loose behind the panel. MK1s and 2s with the 3 pin can is bolted to the dash rail above the handbrake
Post by biffofo on Oct 5, 2022 13:20:11 GMT
hi all ive found a rectangular smiths motors relay under the dash which to me looks like a voltage stabiliser ? its got 2 double spaded terminals one marked B with two wires attached and one marked I with one wire ... this it ?
Post by Phil Nottingham on Oct 5, 2022 16:34:33 GMT
hi all ive found a rectangular smiths motors relay under the dash which to me looks like a voltage stabiliser ? its got 2 double spaded terminals one marked B with two wires attached and one marked I with one wire ... this it ? B = Battery (ignition in this case and should be a green cable) I = Indicator switch Green/White cable If colours are DIFFERENT then may very well be the Instrument voltage stabliser - follow cables (LGHT GREEN) from I terminal (= Instruments. Trace flasher unit by sound! Are you on the FB group?
Post by biffofo on Oct 5, 2022 17:37:30 GMT
yes i am , talking to another Phil on there , it is a VS i found a part number on it ( evenutually)
the thing i found is a stabiliser BR1301/00A looks like i am going to have to put the old bulbs back in and then listen for the relay to tick
Post by biffofo on Oct 5, 2022 17:48:55 GMT
I am struggling as the only wiring diagram i have is from the workshop manual and it is proving like Liz Truss's policies -- difficult to see what is what and where its all going Is there anywhere to get an A3 size diagram .. in colour maybe
Post by Phil Nottingham on Oct 5, 2022 20:38:41 GMT
yes i am , talking to another Phil on there , it is a VS i found a part number on it ( evenutually) the thing i found is a stabiliser BR1301/00A looks like i am going to have to put the old bulbs back in and then listen for the relay to tick There is only one other Phil - me. P5OC members can be supplied with a large colour PDF version (via myself) or a printed laminated version from the club
Post by Mike’S-a-loon on Oct 6, 2022 0:19:35 GMT
Hi Phil,
can you send me a copy of the PDF please?
