Post by enigmas on Mar 18, 2023 10:41:36 GMT
NOTE: The information, images and videos below are provided purely for entertainment purposes. The intent is to give an overview of how an (aftermarket) R12 refrigerant underdash AirCon system can be recommissioned to viable operation in a Rover P5 Coupe.
(PPE)
Appropriate Personal Protective Equipment.
In the interest of personal safety as with any work on motor vehicles ensure that appropriate PPE is worn. When working on A/C systems wear goggles/glasses and rubber gloves to protect your hands and eyes from any sudden escape of refrigerant. It's not likely with due care, but it pays to be cautious in the event of frost bite.
Comments added at a later date to clarify various issues, devices and tech methods used in recommissioning this older model underdash R12 Aircon System will be added in a GREEN ITALIC font.
Overview
When I recommissioned my P5 MK3 Coupe many moons ago (it was re-engined with a Leyland P76 4.4 litre V8 amongst other things, hence this topic is in the Modified section.) During this time, I fitted an under dash AirCon system. The AC system was sourced from a Ford Econovan that I owned and later sold, obviously minus the AC. It's an after market (R12 refrigerant unit) utilizing a UNICLA compressor.
R12 refrigerant although a staple for car ACs up to about the 1990s (due to it's negative effects on the planet's ozone layer) is now illegal to use. It was and probably still is one of the most effective refrigerants for cars. Over the ensuing years its been replaced by several alternative types of refrigerant. One of the most commonly used and now slowly being outdated is RI34a as it's less harmful to the environment.
Discharging R12 refrigerant straight into the atmosphere is a criminal offence in OZ and the USA with heavy penalties applying. Most professional AC shops have recovery machines for this purpose. Recovery is normally free as R12 is both expensive and difficult to obtain. Interestingly it's still used and also available on the black market in some countries.
Moving on.
In OZ, unlike the United States, car enthusiasts couldn't legally (until relatively recently) recharge their car's AC systems. Tools and equipment to carry out this type of work was also costly and like other areas of car repair/maintenance shrouded in mystery and technical jargon.
In the USA both small handy sized cans of refrigerant (R134a) and the tools/equipment required to restore the viability of a car's AC were/are readily available at reasonable prices for DIY car enthusiasts.
If you can read, research where required, follow a methodical process and work in a safe manner, installing and/or repairing a car AC system is a viable option for a keen auto enthusiast.
With the aid of the Internet, Youtube and the vast amount of resources available via Ebay, as well as a legal use refrigerant for the DIY market, it's a straight forward option to recommission a seemingly old style R12 AC system in OZ.
Most if not all Rover cars up to the late 80's or whenever the mandated AC refrigerant gas changes were introduced, if factory or aftermarket fitted with an aircon system, would have used R12 refrigerant gas. These systems can now be made viably operational again at minimal cost and with a degree of efficiency comparable to that of the original R12 refrigerant. Neither the original compressor nor condensor need be changed. These older style systems were fitted with receiver/dryers and yes this component would need to be changed. These components are still available aftermarket and are inexpensive. I purchased 2 spares, both cost less than $40 AUD each.
Recommissioning & Recharging an Older style R12 AC system.
Here's a picture of the interior of my MK3 P5 coupe showing where the aftermarket UNICLA underdash A/C evaporator assembly incorporating the 3 stage blower fan is positioned.
(PPE)
Overview
Moving on.
