Post by neil55 on Apr 18, 2023 10:04:00 GMT
hi all, is there a diagram or something to show where all the points for greasing are on a coupe ?
Post by Phil Nottingham on Apr 18, 2023 12:26:52 GMT
There are only nipples on the prop shaft sliding joint and OEM prop shaft UJs - most were sealed for life
Post by dmaxwell on Apr 18, 2023 15:43:09 GMT
I could be wrong but aren't there grease nipples for the front wheel bearings?
David California
Post by Phil Nottingham on Apr 18, 2023 21:29:31 GMT
None that I have seen. Some aftermarket track rod ends have them and some owners have added them to the suspension ball joints
Post by lagain on Apr 21, 2023 13:16:22 GMT
I could be wrong but aren't there grease nipples for the front wheel bearings? David California No grease nipples, just ease off the end cap, clean out the old grease if it looks manky and add fresh grease, l use castrol LM. Do not put in too much
