Post by Jens Munk on May 14, 2023 13:11:44 GMT
Is there any method to translate a RV8 engine number to what engine, year, type, HP, it is (or rather was when new)?
The number in question is 11A37616 and is believed to come from an SD1.
Post by jorhenderson on May 14, 2023 15:40:34 GMT
According to Google, it is a ; 9.35:1 comp ratio from a 1979/80 SD1 automatic
tonys
Post by tonys on May 14, 2023 20:03:22 GMT
Correct, from my SD1 records it's an early 9.35:1 SU carb engine for an automatic (early manuals were 10A...). Judging by the number I'd guess that it might actually be from a 1978/79 car.
They were 155bhp @ 5,250 rpm and 198 lb/ft torque @ 2,500rpm. The SU carbs were SU HIF6. Originally it would have been mated to a BW65 gearbox and if that's still fitted, it should have an 021G prefix, whereas the later BW66 had 068E prefix.
Post by Jens Munk on May 22, 2023 13:59:55 GMT
Thanks!
Do you have this from a book and another reference? The engine is going into an MGB, and the Danish authorities to approve this modification has decided to be very picky (they aren't always) and insist on a document stating the power of the actual engine number.
Correct, from my SD1 records it's an early 9.35:1 SU carb engine for an automatic (early manuals were 10A...). Judging by the number I'd guess that it might actually be from a 1978/79 car. They were 155bhp @ 5,250 rpm and 198 lb/ft torque @ 2,500rpm. The SU carbs were SU HIF6. Originally it would have been mated to a BW65 gearbox and if that's still fitted, it should have an 021G prefix, whereas the later BW66 had 068E prefix. <script type="text/javascript" src="moz-extension://9b346049-67fb-4443-a3bc-586cd3ba3ca8/injectedPasswordless.js"></script>
Post by jamesh on Jun 4, 2023 21:25:34 GMT
Post by Jens Munk on Jun 5, 2023 13:11:29 GMT
Yes - thank you. <script type="text/javascript" src="moz-extension://9b346049-67fb-4443-a3bc-586cd3ba3ca8/injectedPasswordless.js"></script>
tonys
Post by tonys on Jul 4, 2023 18:04:17 GMT
Jens
Apologies for the delay in replying as I've been 'offline' for a while and have only just seen your comment.
The information came from James Taylor's book on the RoverSD1, which includes a section on the RV8 engine numbers/dsecifications.
I've re-read what I wrote and it reads as if I might have access to official records, which I don't!
