Post by ricky8664 on May 29, 2023 15:23:01 GMT
Pawing over the bits i've found in the boot of my saloon I have come across the two original inner wings which I fortunately retained after removal as they had several brackets spot welded on them. I still have the piece of wood and the car jack and wheel brace which attach to the left hand inner wing. Unfortunately the right hand inner wing has a couple of brackets too, which I assume also had something attached but I do not have any wood to attach to the right hand inner wing, and have no recollection of what was attached on the L/H side or whether it was missing from my car or whether the brackets were just spares.
Any ideas? Well obviously you will have ideas, but please tell me as I haven't a clue, given I removed the inner wings over 20 years ago!
Post by Phil Nottingham on May 29, 2023 18:35:14 GMT
The right inner wing just had a shaped hardboard covered with the black Hardura to match the rest. The brackets re there as spacers and fixings for the self tappers to hold it in place
Post by ricky8664 on May 30, 2023 9:40:06 GMT
Thanks. I found the r/h side piece of hardura with a bit of damp hardboard, but as I was looking for a bit of wood like that for the jack support, I didn't make the connection as I removed it so long ago. Just need some new hardboard. Can add that to the list of hundreds of things needed to finish it off once resprayed.
