Post by cheepskatebob on Jun 24, 2023 6:16:06 GMT
Does anyone know if the cast sump pan fitted to later Triumph stags will fit the P5B?
Post by enigmas on Jun 24, 2023 8:11:48 GMT
It was a universal transmission, used worldwide by many auto manufacturers. So yes you can fit it. The two issues that I'm aware of is: 1. The size of the front servo, depending upon which servo was selected, (there are at least 3 sizes that I am aware of) and
2. Certain valve bodies with differing selector options may not clear as the transfer tubes may foul with the pan base.
Not all trans pans are precisely the same depth. Some are "slightly" deeper to accommodate the largest of the front servos. At least this is the case in OZ with big Ford 6s using BW35/40 transmissions.
All pans have the same bolt pattern and use the same pan gasket.
If you fit the Triumph front servo, valve body and oil transfer tubes the pan will fit straight on. It may also fit straight up to the P5B BW35 case and clear everything.
Post by lagain on Jun 24, 2023 10:26:14 GMT
From memory my Stag had the later type 65 box with a hole on the side of the sump pan for the filler tube. Although a similar box it's delivery was very different. Have a look on ebay at the gearbox pictures.
Post by eightofthem (Andy) on Jun 24, 2023 10:31:55 GMT
Yes. It will fit. You will need to plug the filler tube connection though. Don't change anything, don't swap anything
Post by cheepskatebob on Jun 24, 2023 14:42:28 GMT
Thanks for the very helpful responses, much appreciated. Now to find one! I can't wait to get ATF in my eyes again! Bob
Post by lagain on Jun 24, 2023 15:54:17 GMT
Thanks for the very helpful responses, much appreciated. Now to find one! I can't wait to get ATF in my eyes again! Bob What is the problem with the existing pan ? (Asking for a friend)
Post by eightofthem (Andy) on Jun 24, 2023 18:34:41 GMT
I have plenty here Bob.
Post by harvey on Jul 2, 2023 12:18:22 GMT
Ford Cortinas had a cast ally sump without a threaded dipstick hole in it, just a plain ally sump. I've had them and sold them in the past.
