Post by jeff5b on Jun 28, 2023 12:51:34 GMT
Hi I need to have my gearbox rebuilt or get a an exchange unit. I have been offered a gearbox with the following numbers on a plate or cast into the casing.
These two are stamped on a plate Part No: 594236R Serial: B11582
This is part of the casing 0465066906L VF1
There is another number on the casing but other than 0465065... I can't read the rest, might be 800. I have checked the numbers as best I can, but only found out that it is probably a four speed refurbished by Rover, (R at the end of the number and the plate says "Factory Rebuilt Unit).
Question is this a BW35 ? Many Thanks Jeff
Post by lagain on Jun 29, 2023 9:20:03 GMT
The type 35 box is a 3 speed box. It is better to get your own box rebuilt as anything that you buy will be a risk.
Post by eightofthem (Andy) on Jun 29, 2023 18:24:08 GMT
Hi Jeff.
What you have there going by the numbers given is a BW65. Sadly they were never fitted to the P5B.
I can help with your transmission either existing or exchange. Will send a PM with my details.
Post by johnwp5bcoupe on Jun 30, 2023 9:00:12 GMT
You won't get better advice than Andy gives or one of his rebuilt boxes
