Post by Eric R on Aug 1, 2023 20:24:27 GMT
Water in driver's footwell. Might be blocked scuttle? Does the scuttle need to be dismantled? Any ideas of a remedy please?
Post by Phil Nottingham on Aug 2, 2023 8:12:57 GMT
There is a drain channel at the top of the wing that can be prodded through from underneath the arch and also via the top of the door frame with the door open.
However it is more likely to be a leaking screen and or or corrosion hole under the rubber
Try some Captain Tolley's leak sealer around the rubber top and bottom of screen and trim
