thor64
Post by thor64 on Aug 17, 2023 18:36:56 GMT
Hi, do you recognise this beastie? It's the rear axle breather. You need to check this is working to get the best from your differential. When I removed mine you could hear the release of air pressure; mine was covered in paint. You have to admire the ingenuity of the Rover engineers; the amount of time put into the design and manufacture of such a small item. There is a little ball bearing inside which moves up and down letting the pressure out and not allowing anything in. It is important to let your axle breath. Attachments:
Post by enigmas on Aug 17, 2023 22:49:50 GMT
A fine little one way valve but still be aware not to overfill the differential with oil otherwise the excess will also want to exit at this point.
Post by neil55 on Sept 13, 2023 14:37:45 GMT
wow ! interesting.. where abouts is it
Post by Phil Nottingham on Sept 13, 2023 16:58:21 GMT
wow ! interesting.. where abouts is it Sits on top of the o/s axle casing
Post by neil55 on Sept 13, 2023 17:24:24 GMT
hmmmm ! thanks, i will check it out , regards neil,
