Post by davewright on Aug 30, 2023 8:01:20 GMT
Is it possible to buy a water pump repair kit for my P5B? Wadhams only seem to list a complete water pump.
Post by lagain on Aug 30, 2023 15:52:57 GMT
Probably best to buy a new one
Post by enigmas on Aug 30, 2023 23:18:58 GMT
If you have the basic skills and a small press rebuilding the waterpump is a straight forward process especially with the early P5B pump. These 2 links below may assist. NOTE: There are 2 styles of impeller on the waterpumps of early Rover 3.5 V8s up to the SD1 engine which uses a slightly smaller diameter solid impeller. Both types use the same ceramic seal. * Early V8 Rover water pump impellers have a "paddle wheel" appearance. * Pumps made in Poland have a more advanced design using curved impellers that function like a plane wing airfoil. Link 1. roverp5.proboards.com/thread/11789/rover-v8-p76-waterpump-sealLink 2. Half way down the page to... "Doing Other Stuff" roverp5.proboards.com/thread/11986/leyland-p76-engine-build
Post by davewright on Sept 1, 2023 12:23:08 GMT
Thank you for that. I could probably do it if I could find the parts in the UK
Post by enigmas on Sept 2, 2023 22:54:12 GMT
