Post by neil55 on Sept 13, 2023 14:33:26 GMT
hi all, ok... open boot,....remove panel which exposes petrol tank, top left there is a hooked petrol pipe that has come away from the tank ! About the size of an old shilling maybe soldered on..... how can i refix without heat, may be a glue or paste suitable........any ideas please thankyou neil.
Post by Phil Nottingham on Sept 13, 2023 16:56:23 GMT
Probably the vent pipe so must be air-tight as it unsafe to leave it open.
They are soldered in but an Epoxy metal based adhesive many work as long as it states it fuel resistant. Mesure the flexi pipe fitted to it is secured so as not to place strain on it
Post by neil55 on Sept 13, 2023 17:20:57 GMT
ok phil thankyou for that, i will get some tomorrow, regards neil
Post by enigmas on Sept 13, 2023 22:10:01 GMT
JB Weld is a very useful epoxy adhesive.
Post by neil55 on Sept 15, 2023 9:13:18 GMT
hi phil just had a thought, before i epoxy weld the pipe back on to the tank, is there an internal pipe or tube that may of fell off, why i ask is when i cleaned the end of the pipe base to re afix there seemed to be a neopreen type washer i peeled away from the base, its just got me thinking ? regards neil
Post by Phil Nottingham on Sept 15, 2023 15:39:01 GMT
Not that I am aware off nor any washer
