roverp5b
whats in your mirror
Post by roverp5b on Jan 2, 2005 21:08:01 GMT
I have fitted Wipac haolgen headlights to my p5 3ltr today. Should I have fitted relays. Thankyou Sean.
Post by Phil Nottingham on Jan 2, 2005 22:32:31 GMT
Yes - as the console light switch can only just cope with normal sealed beams. It will cause a volt drop which causes overheating of the switch. Does it warm up after a spell?
A single HD 20A relay frm Vehicle Wiring Products is easily fitted behind the console and clipped to the speedo fastening
roverp5b
Post by roverp5b on Jan 3, 2005 11:19:44 GMT
:DThamks Phil, I only tried them for the first time last night, regarding heating up of switch I didn't noice to busy blinding other drivers with the high beam. Sean. I will fit relay as you suggest.
