roverp5b
whats in your mirror
Post by roverp5b on Jan 1, 2005 10:51:02 GMT
Has anyone been able to repair these window mechanisms once removed from the door. I have both front ones gone at the moment and dont fancy paying £170.00 plus to replace them. The bit thats worn seem's to be housed in its own casing making it harder to understand the workings. Any guidance much appreciated. Searched the old site but no facts on repairing just removal. Thanks Sean.l???TEXT
Post by Phil Nottingham on Jan 1, 2005 18:56:24 GMT
They are a very poor design and not up to the weight and balance of the glass.
I have heard of people making a new cog and parts can be swapped over to make up a good one from several unworn parts usually taken from the back winders which are hardly used
Ray Pickett Sussex Rep
Guest
Post by Ray Pickett Sussex Rep on Jan 2, 2005 20:26:38 GMT
I fixed mine some years ago (P5b Coupe 73) The gear cog-1/4 had come away from the arms. I used pop-rivits to replace the spot weld. It's held for the last 10 years (summer use only - 30,000miles? )
Post by Roy F on Jan 12, 2005 11:24:49 GMT
All you have to do is get the back ones and drill out the spot welds/rivets that hold the winder case to the arms, do the same on the front and then re rivet the good one in its place, you might want to put a spot of weld on it as well for strength. This is usually what happens to reconditioned ones...
Post by Sean on Jan 15, 2005 20:22:10 GMT
Cheers Roy.
Post by Deleted on Jan 16, 2005 0:32:59 GMT
i put a add on a banger site 4 a window winder and got 2 offered me the site was wellbent in the 4 sale piece got one winder £5+post cheap
