Post by Deleted on Apr 10, 2007 20:21:01 GMT
Hi all i took the car out to day ruhing ok stoped at the shop went to start the car and it sounds like it is only runing on 7 and there is a taping noise as well so i rang for the recovery to get home any ideas
Post by Phil Nottingham on Apr 10, 2007 21:34:39 GMT
Could be a hydraulic tappet/camshaft failure or just a plug/lead failed. Identify which cylinder it is by removing a plug lead in turn with engine running to see which one makes no difference. Check spark and plug is OK if so, then remove rocker cover on that side to see if both valves open once during 2 turns of engine using socket to turn engine.
Report outcome - some symptons would usually have been present before if its serious
Post by Deleted on Apr 11, 2007 21:25:14 GMT
Hi i have checked sparkplug ok Not fireing on No8 took of rocker cover one valve not hardley moveing put some stuf in to unblock oil ways and free sticking valves The valve and tappet are moveing a bit more now but still fireing on 7 and tapping a lot
Post by harvey on Apr 11, 2007 21:34:08 GMT
Sounds like the camshaft has worn the lobe away.
Post by Phil Nottingham on Apr 11, 2007 21:45:19 GMT
It does point to at a top end overhau and new camshaft - any engine history, black sludge etc? The rear ends of teh camshaftdo seem to have a tendancy to go first.
Remove the tappets and inspect tehm and camshaft
Post by Deleted on Apr 11, 2007 22:29:54 GMT
Thanks for that will it be a big job or could it be a bent valve
Post by Phil Nottingham on Apr 12, 2007 17:14:03 GMT
Both about as much bother - its a matter of what is else you may as well do, or find! Valves do not bend without good cause
Post by Deleted on Apr 12, 2007 20:50:16 GMT
what do i look for once the head is of
Post by harvey on Apr 12, 2007 21:03:18 GMT
If it's the camshaft it's not necessary to remove the heads to do it. As Phil said, valves bend for a reason, usually the camchain jumping.If you want to see if a valve is bent, remove the rockershaft and lay a straight edge along the tops of the valve stems, any bent (or stuck) ones will sit noticably lower.
Post by Deleted on Apr 12, 2007 21:19:46 GMT
THank for your help let you know how i got on
Post by Deleted on Apr 13, 2007 12:02:48 GMT
It could be a collapsed hydraulic tappet. A camshaft failure would not happen suddenly on a trip to the papershop. If the milage is around 70,000 miles i would change the camshaft and tappets anyway. A kit is ludicrously cheap costing less than a full service. Once the one of the lobes START to wear, the damage to the rest of the engine has to be considederd.
