Post by Deleted on May 2, 2007 21:18:32 GMT
Hi i have taken all the valves out of the heads and on the top of each valve there is a rubber type washer can any one tell me where i can get them from and what are they called And all so there was no gaskets on the exhaust manifolds do they need them
Post by Phil Nottingham on May 2, 2007 23:01:18 GMT
Valve seals - they come with decoke headsets usually. RPI?
Strictly manifold gaskets are not required, certianly not on P5B engines but they are often fittedespeically with tubular manifolds with other engine applications. Again these are in the headsets
Post by petervdvelde on May 7, 2007 10:55:56 GMT
Vince,
I would not refit these. I fitted them when overhauling my Sd1 V8 in my MGB and found these broken in the oil 1000km later. I can't see how these function because it are no real seals. Also i believe these are not fitted to all Rover V8's Regards Peter
