Post by Deleted on May 3, 2007 21:32:41 GMT
Hi on my sd1 heads they have single valve springs but on my p5b heads they have double valve springs should i use the double valve springs on my sd1 heads And all so how do you tell the differance of the sd1 heads and the p5b heads they look the same
Post by harvey on May 3, 2007 21:48:49 GMT
The SD1 heads have to use the single valve springs.The valves are bigger in the SD1 heads.
Post by Deleted on May 3, 2007 22:04:35 GMT
I put the two valves together and they look the same size
Post by harvey on May 3, 2007 23:01:40 GMT
SD1 valves are bigger than P5B valves, maybe your heads have been modified to use the SD1 valves already. Easiest way to tell the heads apart is the spark plugs, P5B uses short reach (L92Y) plugs, SD1 uses long reach (N12Y)
Post by Deleted on May 4, 2007 11:39:55 GMT
They dont accept the old short reach 2 valve spring heads for reconditioning at Rimmer bros. They are not lead free friendly anyway.
