brakes
Jun 4, 2007 21:48:46 GMT
Post by Deleted on Jun 4, 2007 21:48:46 GMT
Hi all took the car out fo the first time on sunday drove about 30 miles on the way home went to use the brakes brake pedal went straight to the floor pumped the brake pedal brakes came back then done the same all the way home could it be some thing to do with the rebuild of the engine
brakes
Jun 4, 2007 21:51:14 GMT
Post by Phil Nottingham on Jun 4, 2007 21:51:14 GMT
Unlikely unless you have disconnected the brake lines at some stage - more likely co-incidence through standing idle.
There is loads on this topic - use SEARCH set for 1000 days
brakes
Jun 4, 2007 23:24:48 GMT
Post by Welsh Warlock on Jun 4, 2007 23:24:48 GMT
