bigandy
Post by bigandy on Jun 30, 2007 12:48:01 GMT
hi guys and gals noticed this morn the power steering was making a a gowling noise when turning the wheel seems ok now!!! any ideas??? big andy
Post by Phil Nottingham on Jun 30, 2007 14:45:16 GMT
It could be low on oil - but many system make that noise and it quite normal. Sometimes its causes by air getting in via worn seals other times by the high pressure pipes vibrating on the body.
The colder the oil the worse it will be - ignore it as long as its full with oil and the belt is tight
Post by dorsetflyer on Jun 30, 2007 20:14:30 GMT
A couple of years ago I had the same problem, mainly when approaching full lock either way. The steering wheel also seemed to shudder at the same time. All was cured by topping up the reservoir to the correct height
bigandy
Post by bigandy on Jul 1, 2007 8:33:52 GMT
will check mucho cheers
big a
theroveringmember
Post by theroveringmember on Jul 2, 2007 4:43:31 GMT
I've had my car 22 years & the steering has always sung to me. It's never caused any harm.
bigandy
Post by bigandy on Jul 4, 2007 9:33:53 GMT
she was low on fluid and is now at ease
thanks
big andy
