Post by Deleted on Jul 9, 2007 16:53:35 GMT
Hi all i have just brought range rover v8 engine 1982 is there any thing i need to change to put into my 1973 p5b
Post by harvey on Jul 9, 2007 17:13:49 GMT
Carbs and manifold, exhaust manifolds, front cover and water pump,and if it was from a manual R/R, flywheel and spigot bearing, plus all the ancillaries and mountings.
Post by Deleted on Jul 9, 2007 21:04:47 GMT
Thanks harvey but why do i need to change the front cover and water pump
Post by harvey on Jul 9, 2007 22:07:10 GMT
Range Rover has a long nose water pump with a viscous coupling,(or should have) and it's position is higher , hence the different front cover
