Post by stevemac2002 on Dec 6, 2008 11:27:05 GMT
Anybody got the part number handy for a rear offside brake slave cylinder for a 1964 Mk2a 3ltr?
Post by Phil Nottingham on Dec 6, 2008 12:15:40 GMT
N/s 5/8ths is 301000 - o/s (R) is 301010 - 3 Studs standard
N/s 3/4's is 301120 - o/s is 301130 - 3 studs (P5B have 2 studs)
P5B's for ref are 301200W & 301210W with 2 studs which will fit and these have rubber boots also they they do not last long
These are the Girling numbers as Rover part number is no use - you need to measure the cylinder/piston to see which has been fitted - it could be either but both must be the same which may not always be the case! Let us kmow which you have please
I would advise you Read SEARCH set for 2000 days for more
