Post by Colin McA on Sept 10, 2011 13:35:37 GMT
I am considering fitting a hi torque starter.
My own standard one is getting a tad tired so keen to seen what options I have before it dies.
has anyone fitted one and what was the supplier/brand/part number.
Thanks Colin
Post by Colin McA on Sept 10, 2011 14:03:25 GMT
been doing a bit of searching.
The starter with solenoid underneath like ours is gxe4442. Moss are currently selling these on a sale at a very good price.
Post by johnwp5bcoupe on Sept 10, 2011 14:36:36 GMT
been doing a bit of searching. The starter with solenoid underneath like ours is gxe4442. Moss are currently selling these on a sale at a very good price. Colin I cant remember who but I remember someone got one and the solenoid fouled so double check
Post by Colin McA on Sept 10, 2011 18:06:10 GMT
Cheers John,
I have been discussing with fellow p6 owners and the part number seems to be the same as ours solenoid under type.
Might be close to the coolant pipes but I can get creative if need be. mine isnt dead so I wont be stranded.
Will order one next week, maybe give me time to think.
Colin
Post by Phil Nottingham on Sept 11, 2011 8:05:10 GMT
Post by Kev on Sept 11, 2011 8:32:25 GMT
Don't get the Moss one, i did & it fitted a treat,however when it engaged the teeth on the motor would not engage correctly,upon inspection it appeared that the throw on the cog was short of the plate teeth....horrible sound & messed up the teeth somewhat.Moss took it back ok & i ended up refitting the original which as you all know is a pain in the A@@e.
Big Kev.
Post by Colin McA on Sept 11, 2011 9:51:04 GMT
Bit concerned about that one Kev,
was this recent? I picked them out due to their sale price.
Post by enigmas on Sept 11, 2011 12:14:20 GMT
I have one from a Range Rover fitted to my Mk3 4.4 P76 engined hybrid. Its very compact and spins the engine over like no-ones business.
Post by Kev on Sept 11, 2011 16:38:11 GMT
Hi, No can't say it was recent,i just thought as i was fitting a brand new engine i would fit one of these as well. Moss were helpfull but couldn't understand why it wouldn't suit the P5b.
Big Kev.
Post by enigmas on Sept 12, 2011 22:30:29 GMT
Not so sure about the straight Rover engine application but on mine there is a need to run an 1/8" spacer plate otherwise engagement of the gears is too deep and it may end in a situation such as Kevin is describing. (Tooth engagement of the Rover pinion gear and the P76 drive plate is perfect apart from the spacer I just mentioned) There may be variations in the manufacture of the 'flex plates' that cause this situation. I needed this starter as the compression of my engine is around 11:1 and even the P76 starter would struggle and eventually the bush at the nose of the unit splits. The Rover gear reduction starter is a tiny unit in comparison...looks like something out of a small Japanese car.
Post by Warwick on Sept 13, 2011 2:33:24 GMT
Vince,
The one you have from a Range Rover would have been an aftermarket unit too. Before they became available we used to use a locally made Bosch starter for a Holden V8. Ritters sold them after replacing the alloy nose casting with one designed to adapt it to the Rover engine and rotate the solenoid to the required position. These were more durable and turned over the Range Rover engine a bit faster. But a high torque unit is now a better option. The motor is probably a Nippon Denso or something similar.
Post by Colin McA on Sept 18, 2011 15:52:24 GMT
Just fitted the new unit. Getting the original out was easy enough, the hardest part is dropping it down but I just turned it 180* and with some gentle twisting and turning it was out. New H/T motor went straight in even the getting to the bolts are easy to get to now. The engine spins over really well and quieter. Looking at my old one it is tired and some of the teeth are chipped. I will see how it goes but I am very happy with the unit and the price that Moss have it at was a bargain. £148. in the carriage. This time last year I got a starter for my SD1 overhauled for £100 (though it was really badly burnt out). Colin
Post by johnwp5bcoupe on Sept 18, 2011 17:56:52 GMT
Result
Post by Deleted on Sept 18, 2011 19:11:34 GMT
That looks very nice and a lot easier to handle!
Is it the GXE4442X that kev said didn't engage with the starter ring?
Post by Colin McA on Sept 18, 2011 19:24:32 GMT
it is the gxe4442x from Moss.
I spoke to the moss tech guys who couldn't confirm this problem. If I get problems it will be going back, I did read something about a spacer plate for some H/T motors.
I was happy to take a chance on it after reading all the replies and also the moss guys.
Colin
Post by Warwick on Sept 19, 2011 3:12:48 GMT
Should hurt less if it falls on your head.
Post by enigmas on Sept 25, 2011 2:44:55 GMT
Yep, that looks like the unit in my Rover. The best things about it are the small physical size and the the reduction gearing. It's a great little unit
