Post by corbin on Mar 25, 2012 18:38:31 GMT
Hi folks,I'm needing lots of technical info and help from those who are experienced in this conversion. I have been offered a ZF4hp22 gearbox from a Jaguar along with a rover v8 bell housing to convert my v8 coupe to 4 speed. Never having seen this done, is there a list of parts thats required in addition to complete this conversion. Thanks
Post by petervdvelde on Mar 25, 2012 20:31:54 GMT
I am restoring a P5B Coupe and replacing the BW35 for a 4ZF HP22. As far as i can overloop the mods, following things need to be done: -shorten the propshaft by 87mm -change the mountings on the subframe -find a suitable filling pipe (from a Sherpa van or Range Rover) -modify the exsisting lever or fit the one from a Jaguar or Range Rover -pipes or hoses for the oil cooler in the radiator have to be made -get a speedo cable made
I got the propshaft shortened and balanced and changed the mountings on the subframe. I have a filling pipe from a sherpa van but i will source one from a Range Rover because the Sherpa pipes begin near the waterpump and i believe the ones from the Range rover start near the bulkhead
Regards
Post by corbin on Mar 26, 2012 6:45:55 GMT
Thank you Peter, I think the range Rover filling pipe comes very close to the p5 original position so is prefered. Do you know what happens in the flywheel area, are things a straight swap with the torque converter etc? Thanks
Post by eightofthem (Andy) on Mar 26, 2012 14:53:43 GMT
How about some photos of the rear mounting set up for the new box??. I am no expert on autos,but if your box came from a B.M.W then the input shaft may well be different. As for tourque converter you may have to change to a rover??? maybee the B.M.W has more power ?? i dont know. There is a set of spacers to go with the conversion as well as a modified flex plate to suit. If you have trouble finding these i have some i could take dimensions for you to have made. There is also the issue of selector, is the B.M.W electronic??.If so you would need the E.C.U, and some also have a digital speedo, so no cable drive attatchment for your speedo. The only one i am not sure about is the convertor,you may have to seek more help on that. Over to you Harvey. ( some photos would be nice too )
Post by harvey on Mar 26, 2012 15:38:24 GMT
Post by petervdvelde on Mar 26, 2012 16:36:32 GMT
gents,
I have a box from a Sherpa and have all the parts on Harvey's picture. Attached a picture of the modified mounts on the subframe
Regards
Post by petervdvelde on Mar 26, 2012 16:40:04 GMT
i copied the picture directly from the camera but i believe this didn't work.
regards
Post by petervdvelde on Mar 26, 2012 16:46:51 GMT
another attemo....
Post by eightofthem (Andy) on Mar 26, 2012 18:48:26 GMT
Your photo did not show up, could you post another please.
Post by petervdvelde on Mar 26, 2012 19:18:04 GMT
another attemp
Post by petervdvelde on Mar 26, 2012 19:22:41 GMT
Post by petervdvelde on Mar 26, 2012 19:57:33 GMT
Another attemp. I replied yesterday to another thread and could attach foto's which gave no problem. I can't notice any difference
Post by petervdvelde on Mar 26, 2012 20:02:20 GMT
Size is ok. Try if renaming the file helps
Post by eightofthem (Andy) on Mar 26, 2012 20:10:28 GMT
Sorry does not show on my P.C . It may be my end at fault,
Post by harvey on Mar 26, 2012 22:13:32 GMT
Sorry does not show on my P.C . It may be my end at fault, It's not just you.....
Post by petervdvelde on Mar 27, 2012 9:26:31 GMT
I assume the problem is on my side i am logged in but get a message that i am not logged in. Will go to the "board problems"
Post by petervdvelde on Mar 27, 2012 9:53:31 GMT
Post by colnerov on Mar 27, 2012 14:25:38 GMT
Hi, yes the photobucket link works.
Colin
Post by eightofthem (Andy) on Mar 27, 2012 18:15:19 GMT
Nice job of the mounting did you do this in situ,or did you remove the subframe?. Also did you use the bw 35 rubber mount?
Post by petervdvelde on Mar 27, 2012 21:46:34 GMT
Thanks. I used the rubber mount of the BW35 and the bracket (which i had to modify) I changed the mountings in situ but the modified mounting on the subframe is only tackwelded. I will remove the subframe (and weld it) to get it shotblasted and painted but i needed to do the modification of the mounting with engine, ZF4 and propshaft mounted in order to keep an identical propshaftposition/angle. With the engine and BW35 in the car, i made a wooden jig between crossmember (not the subframe) and propshaft so that i had the correct position of the propshaft.
Regards
Post by eightofthem (Andy) on May 26, 2012 17:00:21 GMT
Well i started to strip me zf box today,and this is how i got on. Please bear in mind that i am no expert in automatic transmissions,and this is my first attempt at one. All comments are much appreciated as knowledge is best shared i think. so here goes.( Click on image)
Post by petervdvelde on May 27, 2012 14:07:49 GMT
Eightofthem
You are braver then i am. I send my ZF4HP22 to Ashcroft for overhaul but i am interested to see how the box looks on the inside so keep posting pictures please. Regards
Post by eightofthem (Andy) on Jun 10, 2012 15:26:26 GMT
Upon stripdown of the valve manifold block,i found that the restrictor valves did not match with what the overhaul manual stated,mainly the large restrictor and the small restrictor,were in each others places going on the books version,and there is another restrictor that the book does not mention. SR =small restrictor LR= large restrictor MR=medium restrictor This is where the D.I.Y home mechanic comes unstuck!!. I have decided to place the restrictors as per the manual,and put the other one that is not mentioned back in its original spot. Does anyone know otherwise? . All comments welcome !!!! UPDATE ON THIS,THE BOOK WAS WRONG,THE RESTRICTOR WASHERS ARE AS SHOWN IN THE PHOTOS,AND AS FOUND UPON STRIPDOWN. THERE ARE A FEW MISTAKES I HAVE FOUND WITH THE REPAIR MANUAL SO FAR also tagged on to this thread is a slideshow (click on image) of the valve block strip down,clean and inspection. I was suprised how much crud (mainly aluminium bits jammed in places) i found
Post by stevew on Jun 10, 2012 18:43:16 GMT
Upon stripdown of the valve manifold block,i found that the restrictor valves did not match with what the overhaul manual stated,mainly the large restrictor and the small restrictor,were in each others places going on the books version,and there is another restrictor that the book does not mention. SR =small restrictor LR= large restrictor MR=medium restrictor This is where the D.I.Y home mechanic comes unstuck!!. I have decided to place the restrictors as per the manual,and put the other one that is not mentioned back in its original spot. Does anyone know otherwise? . All comments welcome also tagged on to this thread is a slideshow (click on image) of the valve block strip down,clean and inspection. I was suprised how much crud (mainly aluminium bits jammed in places) i found You may find this strip down and rebuild procedure helpfull to overcome your problem, try this link www.cowdery.org.uk/zf.phpHope this is helpfull. Steve
Post by eightofthem (Andy) on Jun 13, 2012 19:13:01 GMT
Thank you steve,thats great,it all adds to the weight of information in one place should anyone be lookin.
