Post by Dean Hovland on Jan 6, 2014 8:13:08 GMT
Mr Green doesnt have one . Im in Spain , so having mine rebuilt is out of the question. Anyone have one for sale ? 11AC i think is the one i need ?
Dean
Post by Deleted on Jan 6, 2014 9:49:49 GMT
Mr Green doesnt have one . Im in Spain , so having mine rebuilt is out of the question. Anyone have one for sale ? 11AC i think is the one i need ? Dean If you have the workshop manual 3.5 supplement and basic tools/skills including a pulley extractor, the 11AC is pretty straightforward to overhaul. I've done two. Both the front bearing and the rear needle bearing are readily available as are the brushes. The only part that might need the attention of a machine shop are the slip rings which might be a bit grooved. A light skim in a lathe is sometimes needed. The electrics are so simple that there's rarely a problem there.
Post by guidedog on Jan 6, 2014 16:49:40 GMT
You can get spares or a recon unit from JRW
Post by Dean Hovland on Jan 6, 2014 18:17:51 GMT
You can get spares or a recon unit from JRW Do you know of another supplier for recon units or spare parts ?
Post by Deleted on Jan 6, 2014 19:31:56 GMT
You can get spares or a recon unit from JRW Do you know of another supplier for recon units or spare parts ? Dean, I just responded to your PM but if you check out Fleabay under Lucas 11AC you will find all the spares you need even spare diodes.
Post by guidedog on Jan 6, 2014 21:06:03 GMT
Thanks for that Resurgam, Saves me looking up anything else. I always use JRW.I know I will get the right parts
Post by Smallfry on Jan 9, 2014 20:42:20 GMT
I agree with Resurgam. The 11AC is simple to rebuild, so Its not worth paying over the odds for a reconditioned unit.
Of course you could always convert to a more modern "all in one" unit (I would) but thats your choice, unless you wish to maintain originality.
Post by Dean Hovland on Jan 10, 2014 18:14:44 GMT
Post by harvey on Jan 10, 2014 18:38:07 GMT
Post by Dean Hovland on Jan 10, 2014 18:50:51 GMT
Thank you Harvey
Post by Deleted on Jan 10, 2014 19:50:26 GMT
I dont have a lathe or bearing pullers . The parts i could need and postage works out more expensive then a recon unit. Is there any other suppliers of new or recon 11ac alternators ? except Wadhams or Mr Green ? Probably not but why not use them? You might find that the recon'd unit comes without the pulley!
Post by Simon H on Jan 10, 2014 21:42:58 GMT
Dean, there are a couple of NOS 11AC alternators on there as well. They are listed as being for Aston Martins or something but can't be far off being suitable for the Rover. If the seller doesn't want to post to Spain I'd happily do it at cost if you buy one of them and get it delivered to me in the UK. The same goes for the parts to refurb an alternator - at least they'd all be in one package going to Spain. link
link 2
Good luck Simon H
Post by Dean Hovland on Jan 10, 2014 22:25:46 GMT
link 2
Good luck Simon H Thank you Simon , ive mailed them both and asked if they would post to Spain. Anyone know if they would fit a p5b ? i can see the terminals are different.
Post by Dean Hovland on Jan 11, 2014 9:40:17 GMT
Im bidding on item number 221349785170 on ebay ,,, your thoughts ?
Post by Phil Nottingham on Jan 11, 2014 14:10:25 GMT
It depends - there is a left hand and right version as to the position of bracket for adjuster bar. This can be repositioned though
Post by Dean Hovland on Apr 12, 2014 18:41:17 GMT
So after replacing alternator twice , using two regulators and relays , it turns out to be a problem with the signal supply to the alternator ! Anyone need a 11ac alternator :-)
Post by Phil Nottingham on Apr 12, 2014 21:10:18 GMT
Well there is always a simpler answer!
Post by Dr Bob on Apr 12, 2014 22:01:52 GMT
So after replacing alternator twice , using two regulators and relays , it turns out to be a problem with the signal supply to the alternator ! Anyone need a 11ac alternator :-) Possible that I will need one- pm me with cost Dr Bob
Post by Dean Hovland on Apr 13, 2014 12:58:04 GMT
PM sent Bob
