Post by Warwick on Jun 13, 2014 4:12:58 GMT
Cyf, The cheapest way to fix the problem is to put the P5B in the garage and go for a nice long drive in heavy traffic in the Range Rover. Then when you next drive the P5B you will quickly realize that there is no clonk anymore; just smoothness and silence.
Post by enigmas on Jun 13, 2014 7:25:46 GMT
Boys some of your drive train noise is incorrect adjustment of the BW35 kick down cable...too much pressure at idle...try backing it off a few turns at a time. Cyf, it doesn't clonk when it's cold because the gear oil in the diff is more viscous when cold. Try using a 50/50 mix of 90 and 140 wt gear oil (more viscous)
Post by Roy of the Rovers on Jun 13, 2014 10:58:48 GMT
My English 'clonk' was going into gear, changing up through gears (unless under heavy acceleration, changing back down to first when coming to a standstill and finally when coasting about 30mph in D and then blipping the throttle. You can hear a clonk from the rear when it takes up the slack and then coasts again. I have a spare pair of half shafts as well, just in case.
I havent done this job before but Im presuming that when the half shafts and prop are removed the diff can be pulled and simply replaced like for like with the new one. Im assuming there arent any additional washers I need to insert when refitting apart from a new gasket?
Post by Phil Nottingham on Jun 13, 2014 18:58:26 GMT
Yes its a simple as that but some seem to have terrible trouble actually removing the half shafts as the hub flanges can corrode together (just a little!) and slide hammers are not the solution as the pressure is in the wrong place so just a few taps with a narrow drift on the stepped joint is all that is needed
Post by enigmas on Jun 14, 2014 2:09:52 GMT
Roy, your description suggest that a big portion of 'your' issue is too much pressure in the BW35...try backing off the cable adjustment. This what is causing the clonking as it drops back into 1st (at too high a speed) PS. Don't go for the hard/difficult/expensive fix before you try the simple ones first. (i.e. Don't make a mountain out of a mole hill unless you need the stress. )
Post by cyf on Jun 14, 2014 7:34:40 GMT
I'll try the cable adjustement trick and see what happen
Post by Deleted on Jun 14, 2014 15:41:28 GMT
Ah...mais oui. Clonque!
Post by Steve P5b on Dec 17, 2014 18:29:38 GMT
kaiser
worth his V8 in gold!
Post by kaiser on Dec 17, 2014 18:58:33 GMT
Or not, more to the point. I only get a picture of a black and white TV, but no video
Post by Steve P5b on Dec 18, 2014 19:40:45 GMT
Or not, more to the point. I only get a picture of a black and white TV, but no video Works OK for me.
Post by Warwick on Dec 19, 2014 2:18:11 GMT
Post by guidedog on Dec 19, 2014 11:36:18 GMT
A very interesting article Warwick. Life was so short then, 50 is no age today
Post by barryr on Dec 20, 2014 0:21:31 GMT
Glad to hear that! - it means I'm minus two currently!
