jan
Post by jan on Apr 13, 2014 19:36:47 GMT
After reading the article about disassembling the screen wash pump (thanks for the information, 'Chuck' Berry!) in the February 2014 issue of Take Five, I decided to tackle the screen wash of my car which hasn't worked for 18 years. Disassembly went fine and I even managed to unscrew the heavily corroded screws fixing the pump. In the pump cavity where the impeller is supposed to sit, there was a sticky black goo which I removed with a few cotton buds drenched in white spirit. The pump axle has a small square metal vane. I reassembled everything and the pump now turns happily, but no liquid is being moved. I suppose the sticky black goo was the remains of the impeller, so I'll have to try and build a new one myself. But what does it look like? Or can I solve this in another way? Thanks for your ideas.
Jan
Post by Simon H on Apr 13, 2014 20:59:12 GMT
If you are really desperate you could buy THIS ON EBAY or just look out for one at an autojumble or boot sale or something... The impeller is a star shaped rubber thing. The motor spindle is off centre in the pump cavity and the whole thing works a bit like a rotary vane compressor. Simon H
Post by Welsh Warlock on Apr 13, 2014 23:10:40 GMT
I just added a separate pump hidden along the inner wing and pumping through the cap. Looks standard unless you look closely.
I think the pump was about £5
Post by Colin McA on Apr 14, 2014 9:13:27 GMT
Post by Colin McA on Apr 18, 2014 19:33:53 GMT
