Post by redsunbeam on Jan 26, 2007 17:00:18 GMT
Has anybody fitted central locking to their car? If so, was it bought as a kit or liberated from a donor vehicle?
Post by Phil Nottingham on Jan 26, 2007 19:26:59 GMT
One or two have and kits were onc available to do them on any car with compatible locks- its easier with Coupes as they have the so called "modern" locks.
Actually central locking is the one thing I do miss with old cars but then again unless you have a saloon with its worn locks and self locking tendencies its so much more reliable
Post by Deleted on Jan 28, 2007 15:39:16 GMT
hi, do you know where the kits came from? Joe
Post by Colin McA on Jan 28, 2007 22:13:09 GMT
Maplin do kits.
Colin
Post by Deleted on Jan 28, 2007 22:47:43 GMT
i thought about fitting central locking to mine but as phil said the doors lock all but is sels anyway.
Post by Phil Nottingham on Jan 28, 2007 23:00:39 GMT
They can be fixed!
Post by gregwebb on Jan 29, 2007 11:04:50 GMT
I fitted a universal/generic type kit to my p5b coupe . The rear doors were straight forward as the actuators clamped directly onto the existing rod from the interior door lock button. The front doors required removing the door lock assembly from the door and silver soldering a small additonal tag with a small hole in it for the link from the actuator to connect to as the actuator needs to operate in a vertical plane. The routing of the wiring etc was straight forward.
Post by redsunbeam on Jan 29, 2007 16:12:19 GMT
Have found loads of kits on ebay- much cheaper than i thought ;D. Anyone have any experience of these?
10mpg
Post by 10mpg on Jan 30, 2007 21:32:10 GMT
I have a freind whose old boss was P5b nut had several of them apparently, my friend fitted one of his bosses cars with full remote central locking all 4 electric windows and modern sound system etc etc. The again my mate is an auto-electrician so i imagine it was easy for him, i can ask him for any hints or tips if you like?
Post by redsunbeam on Jan 31, 2007 15:43:59 GMT
Any hints, tips and advice would be gratefully recieved before i get up to my neck in it.
