Post by elan71 on Jul 12, 2014 9:31:07 GMT
Hello, my left side and tail lights quitted working. I have current at the fuse box but no current at the related cable connector in the engine compartment / boot. To have a point to start from: Is there any "known spot" which is prone for causing problems with this cables? Any advice to sort this out?
Thanks Alex
Post by Steve P5b on Jul 12, 2014 9:37:45 GMT
Hi, could it be you have selected the "park" position on the light switch. Try moving the switch back to the central position and then continue to the other side for full sidelights.
Post by elan71 on Jul 12, 2014 10:55:29 GMT
Hi, could it be you have selected the "park" position on the light switch. Try moving the switch back to the central position and then continue to the other side for full sidelights. Thanks Steve, as my Rover is LHD park position should light up left side as well. So just to clarify, my side / tail light on the left are not working in either position of the light switch (right working fine when switch in main position).
Post by Steve P5b on Jul 12, 2014 13:38:00 GMT
Ah , I see, from memory the localised placed to look would be at the switch. Sorry, don't have access to a wiring diagram to be more specific.
Post by Phil Nottingham on Jul 12, 2014 14:14:40 GMT
Have you checked the fuses and the connections - each side is separate. failing that ensure the switch terminals are connected and correct
Post by elan71 on Jul 19, 2014 8:32:59 GMT
Stupid me: I always checked the side / tail lights fuse, which was ok. Did not realize, that it also will not work on main when parking lights fuse is broken. Now sorted out, thanks.
Alex
