Post by anklesn on Jun 28, 2015 16:55:31 GMT
Hello, just been for a run in the P5b Coupe. My mechanic has been playing with the carbs to reduce idle speed which is now better but nortice some misfiring. Anyway just came home, turned engine off for a few mins then tried to restart, engine did nit turn instead, a very loud machine gun type sound when I turn key! Any ideas please thx Noshir
Post by harvey on Jun 28, 2015 17:30:50 GMT
Flat battery.
Post by anklesn on Jun 28, 2015 17:41:03 GMT
Just jumped it and started straight away. Is it a weak battery? Thx
Post by harvey on Jun 28, 2015 17:48:55 GMT
Just jumped it and started straight away. Is it a weak battery? Thx Either the battery itself, or a very poor connection between the battery terminal and the post, so try cleaning those first, if not, then by jumping it you've eliminated the rest of the system from the battery onwards. [edit] Obviously don't discount the possibility that it just wants charging.....
Post by anklesn on Jun 28, 2015 19:07:18 GMT
Thx Harvey will give the terminals a clean. Many thx
Post by enigmas on Jun 28, 2015 22:47:34 GMT
From your primary comment I'd say you need another mechanic. If it's idling fast, and has a misfire it may have a vacuum leak somewhere but it sounds like your mechanic is fiddling with the carbs rather than accurately diagnosing it and implimenting the appropriate fix.
Post by anklesn on Jun 30, 2015 22:47:06 GMT
Thx Enigmas, I wish I could find someone near me who knows these cars well enough! Regs
Post by enigmas on Jul 1, 2015 2:32:10 GMT
Look for any garage that specializes in English classic cars...Jaguar, Daimler, Triumph, Wolseley, Morris, as they all used CD carbs in various forms (SU or Zenith Stromberg) or learn from this tech board. There will be more than enough respondents to answer your questions and provide guidance if you ask the appropriate questions?
Post by anklesn on Jul 1, 2015 6:00:00 GMT
Thx v much
