Guus
Post by Guus on Sept 8, 2015 20:53:59 GMT
Hi, Still in the process of rewiring my Rover. Unfortunately the diagram doesn't show how the 4 wires should be connected to the alternator. See picture: the big brow wire is obvious, but does anybody know which colour of the other three wires should go to what connector? Thnx Guus
Post by Simon H on Sept 9, 2015 12:43:08 GMT
Does this help? The thick Brown /White is obvious Next is Brown / Dark Green Then Brown / Pale Green The one on it's own is Brown / Yellow If the original insulating shrouds are on the wires the brown / dark green can only fit on the terminal next to the big one due to the shape of the shroud.
Guus
Post by Guus on Sept 12, 2015 9:31:25 GMT
Thnx Simon! My colours are slightly different. Besides the big Brown-white and Brown-yellow I have brown-green and Brown-purple. Can you find out to what connector on the 4TR box your Brown-lightgreen and -dark green connect? The + and F? Thnx
Post by johnwp5bcoupe on Sept 12, 2015 10:25:46 GMT
Thnx Simon! My colours are slightly different. Besides the big Brown-white and Brown-yellow I have brown-green and Brown-purple. Can you find out to what connector on the 4TR box your Brown-lightgreen and -dark green connect? The + and F? Thnx Guus when I did mine there was an error in colours on the wiring diagram!! mine is cloth coloured I will try and get a pic later today for you
Post by Simon H on Sept 12, 2015 18:44:41 GMT
Guus, I will check out the wires on my car tomorrow, but if you have a wiring diagram the terminals next to the big brown wire are F- and F+ and the one on its own is '10' if I remember correctly
Post by petervdvelde on Sept 12, 2015 22:37:00 GMT
Guus, This is how the alternator should be connected. You could find out what color the wires in your loom are and then connect these Peter
Guus
Post by Guus on Sept 16, 2015 13:31:15 GMT
Thank you all, This information will do perfectly. Guus
