Post by enigmas on Sept 28, 2015 10:04:56 GMT
Post by gingerbeer62 on May 11, 2016 7:52:20 GMT
Interesting manual and thanks for posting. I note that on page 5 it says the hydraulic fluid is normally engine oil of SAE 10W ? Interesting. Was red hydraulic fluid not around in 1960 I wonder? Cheers Colin
Post by Phil Nottingham on May 11, 2016 19:07:23 GMT
Its the ATF
Post by gingerbeer62 on May 11, 2016 22:41:13 GMT
Post by johnwp5bcoupe on May 12, 2016 8:41:47 GMT
SAE 10 was recommended! colour? ATF Ford M2C 33G is only an oil developed for Auto Transmissions
Post by gingerbeer62 on May 12, 2016 9:36:20 GMT
SAE 10 was recommended! colour? ATF Ford M2C 33G is only an oil developed for Auto Transmissions Ok, so what do most of us put in our power steering reservoir ? Cheers Colin
Post by johnwp5bcoupe on May 12, 2016 9:56:26 GMT
SAE 10 was recommended! colour? ATF Ford M2C 33G is only an oil developed for Auto Transmissions Ok, so what do most of us put in our power steering reservoir ? Cheers Colin Me Ford M2C 33G only because I have it on the shelf all the time
Post by enigmas on May 12, 2016 11:05:49 GMT
I use the same transmission oil (ATF) for the power steering as I do for the transmission in my coupe. (Dexron 3...as the internals of the automatic are BW40 in a 35 case)
