Post by Tim Goddard on Nov 8, 2015 8:36:54 GMT
I know this subject has been covered many times, but I'm still not sure what pump I should get. The Facet pump seems a popular choice, but I'm worried that it may be too noisy. Is there a quieter alternative ? If not, could the pump be mounted in the boot to dampen the noise ?
Post by enigmas on Nov 8, 2015 9:58:26 GMT
Tim you worrying needlessly! Mount the pump lower than the tank...underneath the car if you like? They prefer to be gravity fed. Mount it on small rubber insulating blocks. You certainly won't hear it. They are extremely reliable and maintenance free. You'll wear out before it does.
Post by Phil Nottingham on Nov 8, 2015 11:08:31 GMT
You can hear them ticking but not when driving. Even our Mk2 P5 with its boot mounted twin SU can be heard sometimes (in fact I let it prime before starting so listen to it) and I am part deaf!
Post by Tim Goddard on Nov 8, 2015 18:01:15 GMT
Thanks chaps. I was worried that it would be intrusive at tick over or low speed.
Post by Warwick on Nov 9, 2015 2:12:42 GMT
Or you could use a 'transistorized' double-ended diaphragm pump from a pre-EFI Range Rover. Because they use a transistor to switch the current and the points on the diaphragm only trigger the transistor and don't carry the full current, you don't have the age-related reliability problems of the old SU pumps. Or there is the Japanese copy, by Mitsuba. Facet also make one for the Range Rover tinyurl.com/qh73ppzEdit: Can't find a Mitsuba.
Post by guidedog on Nov 9, 2015 9:47:38 GMT
What ever you do Tim,do NOT get a facet Red Top, you wouldn't believe how noisy they are.I found out the hard way.
Post by davewright on Nov 9, 2015 10:12:52 GMT
I have a Facet in the boot below the tank. I hear it when I switch on the ignition but not once the engine is running. Except, that is, when I am running out of fuel so I get a useful audio warning that the tank is empty and I only have what is left in the floats and pipes to go. This means I can find somewhere safe to pull over if I don't think I can get to a petrol station.
Post by johnwp5bcoupe on Nov 9, 2015 14:27:06 GMT
Thanks chaps. I was worried that it would be intrusive at tick over or low speed. I can hear my Facet priming Tim and when it's time to think of pulling the lever for reserve (this you will loose if you put the pump in the boot unless you want 2 pumps! plus it's too high!!) apart from that I don't hear it! mine is mounted on the gearbox X member on rubber bobbins after the reserve C/O. Pump plus reserve C/O
Post by guidedog on Nov 9, 2015 15:08:50 GMT
Yes John I will be doing the same (subject to copyright) having brought another pump. I installed the Red facet in the engine bay. YUK.
Post by Tim Goddard on Nov 9, 2015 16:52:42 GMT
Thanks for all your advice. That has put my mind at rest.
Post by Warwick on Nov 10, 2015 1:57:50 GMT
What ever you do Tim,do NOT get a facet Red Top, you wouldn't believe how noisy they are.I found out the hard way. That's handy to know Bob. The old Range Rover pumps weren't noisy and as the Facet appears to be a copy of it, I assumed it would function the same. I don't know what the original brand was. Was it an SU?
Post by guidedog on Nov 10, 2015 8:02:24 GMT
Hi Warwick I don't believe it relates to S.U. You will find it in Rimmer Bros. Its U.S.A made. Seemed right for me as it is O.K for engine bay fitment.
Post by Phil Nottingham on Nov 10, 2015 18:34:08 GMT
Facet pumps are totally different and even more reliable than SU's as they use a piston not a rubber diaphragm that modern fuels dissolve (still)
