Post by ozriderp5 on Apr 14, 2017 9:34:37 GMT
Hi All
I've just removed a home made centre consol with a lever fitted to hold second gear.
I want to put it back to original.
Where does the original assembly fit under the dash?
Also, where does the cigarette lighter go?
Any pictures would be great, thanks.
Post by Phil Nottingham on Apr 14, 2017 20:35:02 GMT
See handbook - I do not have one to cover Mk1's as later cars had the column switch. Some period adverts should show it
Post by ozriderp5 on Apr 14, 2017 21:19:34 GMT
See handbook - I do not have one to cover Mk1's as later cars had the column switch. Some period adverts should show it Thanks Phil, unfortunately no handbook.
Post by ozriderp5 on Apr 15, 2017 9:43:27 GMT
Found a picture of a LHD Mk1. Lighter and 2nd Gear Hold look like the go in the middle, I'll see if I can find existing holes. ![](http://i256.photobucket.com/albums/hh186/ozriderxj/Rover%20P5/2nd%20Gear%20hold.jpg)
Post by Phil Nottingham on Apr 15, 2017 21:15:06 GMT
That is where the Cig lighter is on our Mk2. The T handle on Mk1's was criticised for being inconveniently out of reach. There are loads of tapped holes underneath the parcel shelf rail
Post by ozriderp5 on Apr 15, 2017 22:55:20 GMT
Considering how far the car is from original I think I'll move it closer.
On the other hand I doubt it will get used, car will only be an occasional driver so it won't make much difference.
