Post by denis23 on May 31, 2017 10:56:25 GMT
Post by johnwp5bcoupe on May 31, 2017 11:35:18 GMT
Yes Denis the steering wheel has to be removed there is a plate with 4 short screws then 4 long screws holding both halves of the shroud together, the Ign switch I cant say but if you can get a better look at the terminals it may be ok? they were used in several vehicles!
Post by johnwp5bcoupe on May 31, 2017 11:39:06 GMT
Just checked the parts manual and the numbers are the same
Post by denis23 on May 31, 2017 18:37:14 GMT
John, then next question, how to remove steering wheel?
Post by johnwp5bcoupe on May 31, 2017 19:07:00 GMT
John, then next question, how to remove steering wheel? There are some small Allen grub screws on the center boss these release the horn ring then you will see the large nut with the horn push contact remove the spring/clip/washer. then the nut (disconect the battery it could annoy the neighbors) and the wheel just pulls off the splines
Post by Simon H on May 31, 2017 19:57:23 GMT
Just checked the parts manual and the numbers are the same If it's a steering column mounted switch shouldn't it be the anti-theft set up? There might be a bit of rewiring to do...
Post by petervdvelde on May 31, 2017 21:14:40 GMT
John, then next question, how to remove steering wheel? There are some small Allen grub screws on the center boss these release the horn ring then you will see the large nut with the horn push contact remove the spring/clip/washer. then the nut (disconect the battery it could annoy the neighbors) and the wheel just pulls off the splines I believe you don't need to remove the spring/clip/washer. The large nut from the steering wheel can pass without dismantling Peter
Post by johnwp5bcoupe on Jun 1, 2017 7:51:30 GMT
There are some small Allen grub screws on the center boss these release the horn ring then you will see the large nut with the horn push contact remove the spring/clip/washer. then the nut (disconect the battery it could annoy the neighbors) and the wheel just pulls off the splines I believe you don't need to remove the spring/clip/washer. The large nut from the steering wheel can pass without dismantling Peter My insulation washer was too large Peter perhaps another change as years went by?
